products in alphabetical order?
15 years 4 months ago #19607 by sarsells
Three more little questions please.
Firstly, is in possible to order products alphabetically? In some categories there will be about 1000 items. And my client thinks that even with a search facility, it would be easier for customers if items are listed this way.
Secondly, my menu (which is in fact a category module) is displayed as a list. I would like to get rid of the bullets so chose the option div. When I did this (with show title only selected,) I got large spaces between each title. I think this is where the image would go, but I just want the category titles with no spaces. I have set it back to list for now until I figure out what to do.
Thirdly, I tried to change the layout of the login and registration page. I read the document re the css and changed it accordingly. However, these two items still sit next to each other rather than the login on top of the registration. Can you please tell me what to do?
Oh, I just thought of something else. I do not appear to have a proceed to checkout button. Please can you tell me what to do about this.
Many many thanks
Sarah
15 years 4 months ago #19610 by nicolas
1. In your menus/modules hikashop options, you can selecting the ordering column. By default it's the product_ordering column but you can change it to the product_name column so that the products are ordered alphabetically.
2. The bullet points on lists can be removed quite easily by adding some CSS to your template's CSS. If you give a link, we could tell you more precisely what CSS to use.
3. Then it's probably that the CSS file is cached on that you didn't save the CSS file seletion. You should check that and then try again.
4. The proceed to checkout button on the hikashop cart module can be displayed by activating the corresponding option in the cart module's hikashop options.
15 years 4 months ago - 15 years 4 months ago #19620 by sarsells
Thank you. I now have the products in alphabetical order, the proceed to checkout button activatedand have managed to get rid of the bullet points.
However, I have not been able to display the login/registration as described. the url is www.acrossthetracksrecords.com
Thanks so much.
Sarah
Last edit: 15 years 4 months ago by sarsells.
15 years 4 months ago #19626 by nicolas
I can see the login and registration one below the other on your checkout. Your CSS file is probably cached by your browser. Please clean the cache of your browser and try again.
I also don't see any bullet points on your page.
15 years 4 months ago #19628 by sarsells
That is very strange! I have emptied the cache on firefox, but am still seeing the side by side view, but just looked at it on safari an there they were on top of each other! could it be a firefox issue?
15 years 4 months ago #19630 by nicolas
Please remove also the float: left; line of the code:
.hikashop_checkout_login_left_part {
float: left;
width: 250px;
and that will work as well on Firefox.
15 years 4 months ago #19631 by sarsells
Thank you. I will do that.
Can you please tell be how to split the registration part into 2 columns?
15 years 4 months ago #19632 by nicolas
That's not possible with the options. You would have to change the code of the file custom_fields of the view user via the menu Display->Views. That's out of the scope of this support forum.
15 years 4 months ago #19633 by sarsells
OK Thank you for that, I will leave it for now.
Time to create page: 0.095 seconds
