How change layout of products shown in categories?
16 years 1 week ago #2014 by 1fcb
I wanted to change the appearance (color) of the product boxes, that appear when I show the categories. I thought that in Config -> Display the Parameters for DIV (I found no explanation for what the acronym DIV stands for) would change it, but regardless, what background color I chosse, nothing happens for those boxes. Probably my fault... ?!
16 years 1 week ago #2015 by nicolas
The config->display parameter is the default parameters for when you create new modules and menus.
For modules and menus you already have, you should go to the HikaShop menu "Display->Content menus" or "Display->Content modules". Then, select the menu/module for which you want to change the color of the boxes, and then you will also have a color selector on the right.
DIV and LIST are a way of presentation of HTML elements:
www.w3schools.com/html/html_lists.asp
www.w3schools.com/tags/tag_DIV.asp
14 years 8 months ago - 14 years 8 months ago #42032 by gengeru
nicolas wrote: The config->display parameter is the default parameters for when you create new modules and menus.
in this line... Is possible to add a background image? I've seen that it's possible to make this background transparent in the DIV parameters editor but I'd like to add a background image and manage the css properties for the boxes. Where can I found this php file (if exists)?
Thank You
Last edit: 14 years 8 months ago by gengeru.
14 years 8 months ago #42038 by nicolas
Yes, make the background transparent. Then, edit the front end CSS file of HikaShop in the Display tab of the configuration is you want to add your CSS.
The following user(s) said Thank You: gengeru
12 years 4 months ago - 12 years 4 months ago #165109 by robonmatt
Last edit: 12 years 4 months ago by robonmatt.
