hide product listing from not logged-in users
15 years 4 months ago #20378 by emergentec
Hi!
Using this URL "http://..../index.php?option=com_hikashop&view=product&layout=listing&Itemid=111 a unregistered user can get a list of all the products which we would like to hide. how is this possible?
Best regards
15 years 4 months ago #20405 by Jerome
With HikaShop business there is an ACL (Access Level) system which will allow you to assign rights for users depending their category.
So, you can set an Access Level for "Registered" in order to show a category (and so all products into).
You can set ACL for specific products too.
Jerome
12 years 4 months ago #164796 by hashinisera
Why hika shop hide products for logged user?. I need to show my product list for all. but After I logged in. the product list is disappeared :( . How can I fix this issue?
12 years 4 months ago #164798 by Mohamed Thelji
Did you use the ACL option on your products ? if yes, you should probably set the Access level of your product to ALL.
12 years 4 months ago #164916 by hashinisera
Hello Thelji,
Problem solved. :)
Thank You.
Hashee
