Need some help with alignment
15 years 11 months ago #2041 by gratef
Hi there, beginner here and need some help. Here is an image of one product on a menu page. As you can see, it's aligned all wrong. Can someone help me find where I can edit and change this so it looks better?
thanks, gratef
btw, thanks for this cart everyone who works on it.
15 years 11 months ago #2042 by nicolas
It seems to be your template which redefines some of the styles in HikaShop. I can't tell you more without the URL to that page. Could you post it ?
15 years 11 months ago #2056 by gratef
Hi Nicolas, thanks for the response. . . .
I can't post the URL because I'm developing this locally via MAMP, but I could post the code for that page if that would help?
gratef
15 years 11 months ago #2060 by nicolas
Unfortunately, we need to be able to check the page css and html with firebug, a firefox addon which helps fixing CSS and for that we will need to access it directly.
You could try to use it yourself to try to fix your CSS. Here is a link to a nice tutorial on firebug: www.tutorial9.net/web-tutorials/quick-ea...opment-with-firebug/
15 years 11 months ago #2073 by gratef
I already have firebug installed :-)
I will study the tutorials you sent to see if I can fix this. If I have a problem, hopefully, I can address it here later.
thanks, gratef
15 years 11 months ago #2081 by gratef
OK, good, I'm able to adjust some CSS elements and properties via firebug.
But I wish I could find access to the html of the page. For instance, looking again at the original image in my first post: I'd like to change the text 'per unit' to something else. Any suggestions?
15 years 11 months ago #2082 by nicolas
The text strings can be changed in the configuration page under the tab languages. There, you will be able to edit all the strings of HikaShop. The "per unit" one is among the first ones.
15 years 11 months ago #2088 by gratef
Thanks, that was easy. Never thought to look under languages.
