Products Not appearing in Manufacturers
15 years 4 months ago - 15 years 4 months ago #20721 by stonedbloke
Hello.
First time user so please bare with me.
I have created a number of manufactures. When I create a new product the manufactures list appears on the manufactures drop down and I select the appropriate one, alls good at this stage.
From the front end I have created a menu item to shows all the manufactures with the images. When I click on any of the manufactures images none of the products appear.
Maybe the question should be how do I list my items by manufactures.
Joomla 1.6
Thanks in advance
John
Last edit: 15 years 4 months ago by stonedbloke.
15 years 4 months ago #20722 by nicolas
Please edit the file administrator/components/com_hikashop/classes/menus.php and change the line:
if($params=='category'&&empty($params)){
if(in_array($params,array('category','manufacturer'))&&empty($params)){
Then, create a new manufacturer menu item. That should create automatically an associated module for your menu in order to display the products listing.
You can also do that manually by creating a new hikashop category listing module via the joomla module manager and then adding that module as associated module in the hikashop options of your menu.
15 years 4 months ago #20725 by stonedbloke
Thanks for your quick reply.
Have changed the .php code. Still not doing what I wanted.
You can look at the UAT site - host.quksdns10.net/~glorywat/
I have 6 watches which have been assigned to two manufactures. When I click on the manufactures heading the two manufactures appear. When I click on the manufacture they are not populated by the products.
The "Watch" menu categories works just great.
John
15 years 4 months ago #20726 by nicolas
Please do a screenshot of the hikashop options of your menu.
15 years 4 months ago #20728 by stonedbloke
15 years 4 months ago #20746 by nicolas
Please also do a screenshot of the hikashop options of the module "associated products listing for category listing menu 129".
15 years 4 months ago #20983 by FreshIdeas
Please post solution. I am also unable to get a) items to reflect manufacturer when importing and b) the menu to show the products by manufacturer.
15 years 4 months ago #20992 by nicolas
If I didn't post a solution, that's because I didn't get the information I asked for.
a/ Manufacturers are not supported for export and import for now so it's normal it doesn't work.
b/ If you don't give more information on the problem, I can't help you :/
15 years 4 months ago - 15 years 4 months ago #20994 by FreshIdeas
Ahhh, wish manufacturers could be imported. Would save some time.
So, I go into each product file and manually choose the manufacturer (I've pre-set them already).
Then I'm trying to create a menu to pull products by manufacturer. Here is the screen shot:
Last edit: 15 years 4 months ago by FreshIdeas.
15 years 4 months ago #21047 by nicolas
I see that on your menu, you selected the category 2 as the parent category. Are you sure that this category is a manufacturer and not a product category ?
