- Thank you received: 2
Advice users if "Maximum quantity per order" = 2
- emergentec
We've set the "Maximum quantity per order" for all our products for 1. But if a user tries to add the same product another time to the cart he get's the message "Product successfully added to the cart". Is there a possibility to advice the user, that this product is already in his cart?
Best regards
We'll see what we can do for next release.
- emergentec
- emergentec
- emergentec
The only other thing I can think of it that you edited the file show of the view product before updating and thus you don't have the modification of that view in order to handle that option which is just ignored. Please check on that.
- emergentec
Why isn't it possible, that this message appears in the pop up window?
- emergentec
Thank you very much Nicolas
If you have the "add to cart legacy" setting turned off and the HikaShop cart notify plugin enabled, then you should get the exact error message when a product couldn't be added to the cart for some reason.
Now the warning comes out correctly, but instead I can not redirect the car, once the product has been added.
Thank you
Ah yes, with the plugin activated, then there is no automatic redirect to the checkout.
There is no way to have both right now. But that's a good idea.
We'll add an option to the cart notification plugin so that you can have both with the next release of HikaShop.
