Transparent background for Categories & Products??
- squeakstar
- squeakstar
- squeakstar
Also, is it possible to create a default setting like i have found for categories in the options?
thankyou!
For your products, you should edit the hikashop options of the associated module of your menu.
- squeakstar
Note that it's always possible to override the background color in CSS... With the CSS below you can remove all the backgrounds everywhere on the front end of HikaShop:
div.hikashop_subcontainer {
background-color: transparent !important;
- squeakstar
background: (no value) image missing http://www.hikashop.com/media/kunena/attachments/legacy/images/Capture-20110711.PNG
- squeakstar
If you remove the color of the main menu you should not have any color for the modules where you removed the color.
er, sorry, would this acheive what i'm after then ? If so where is this setting exactly?
or would the css you describe achieve what i'm after completely and forever more by default?
cheers!
- squeakstar
thank you!
- squeakstar
I also managed to remove the border from the subcategories by changing the border value to this:
div.hikashop_products div.hikashop_subcontainer{
border: 0px solid;
in /media/com_hikashop/css/frontend_default.css
Where as in Products listing the products appear fine. Can you please tell if i have to switch off some setting.
In you case the problem is the generated thumbnail. Thanks to change the settings of thumbnail generation in Configuration > Main > Images.
