Radio buttons and drop down menu problem
- PhantomPWR
15 years 4 months ago #21269
by PhantomPWR
Radio buttons and drop down menu problem was created by PhantomPWR
We'd really appreciate some advice/suggestions from you guys.
Can you have some variants as drop-downs and some as radio buttons on the same page?
Webpage
The client wants a drop-down for the sizes, but radio buttons for the fabrics. Is there any way of doing this please? We need to limit white space so the page is not too long.
Any suggestions on how to do this please?
Thanks so much.
Jean
Webpage
Thanks so much.
Jean
15 years 4 months ago #21290
Replied by nicolas on topic Re: Radio buttons and drop down menu problem
It's not possible with just the options available.
However, you can do it with a characteristic display override: www.hikashop.com/support/documentation/6...tation.html#override
You apparently already have an override in place, so it's a matter of changing the code in the override file to handle the dropdown display where needed.
- PhantomPWR
15 years 4 months ago #21311
by PhantomPWR
Replied by PhantomPWR on topic Re: Radio buttons and drop down menu problem
Thanks Nicolas, I'll have a look.
