Products Display
15 years 3 months ago #21520 by davidvm
Products Display was created by davidvm
Hello, I'm sorry for this, but I can't figure out the simple action of having my products display on my site. I have many products organized into 4 different categories, so all I want is a main page to display the name of those categories, and then have all the products on each category display on a grid, when I click on each category name.
I've been trying to follow instructions, change settings, check on the forums, but there is just too much information and options and I cannot get this basic feature to work. If I already have my products list, why won't them just display properly somewhere in my site? It is just too complicated, and I need some help in order to get it working. Thank you!
15 years 3 months ago #21522 by nicolas
Replied by nicolas on topic Re: Products Display
Well, there isn't much to it. You can just go in the joomla menu manager, create a new menu item of the type hikashop category listing, save it and voilà. You have a new menu on your front end which will display you your categories and then the products once you click on a category. There is a tutorial which explains just that with screenshots on the page: www.hikashop.com/support/documentation/6...html#categories_menu
15 years 3 months ago #21528 by davidvm
Replied by davidvm on topic Re: Products Display
Hi Nicolas, thanks for the help. Sorry, but I can't still get it to work. All I get is an empty page with a title, no matter how many settings I change:
www.crecogreendesign.com/Pisac/catalogo1
I even checked your Demo backend and set everything just like it for a categories list/div display. I don't know if maybe it has something to do with the modules or the positions, or maybe with the template I'm using. I changed the template to Joomla's default one and still got the same thing. I'm also using a hidden menu, which is not showing on the main menu, but I also tried with a regular menu item and still got the same.
15 years 3 months ago #21540 by nicolas
It's just that you didn't create any category in the main "product category" category, so the system has nothing to display.
15 years 3 months ago #21577 by davidvm
Oh yeah, I finally got it! I had created the categories correctly, but they were just not published!
Thanks!
