Some help from a guru :D
15 years 11 months ago #2387 by niaa32
Hey i would really appreciate if someone could pop over to my site and have a look at what im doing wrong...
www.thewhiterteethstore.com
im in the process of building the site up and i cant seem to get the product heading to display above the products
you can see what i mean by clicking the shop link - then whitening kits.
I was up to 4am trying to figure it out and ended up giving up.
I would much really appreciate some help,
John Stewart
15 years 11 months ago #2390 by nicolas
It seems that you added the product listing module as a normal module on your template just above the content. Which is why it displays on top of the categories listing.
You should go to Display->content module and edit the module with the id 62. Then, go to it's joomla options and unpublish it.
Then, go to Display->content menu and edit your "shop" menu. There, click on the select button next to "associated module" and add your product listing module to it and then save the options of the menu.
That should display the product listing below the category listing.
15 years 11 months ago #2396 by niaa32
Replied by niaa32 on topic Re: Some help from a guru :D
Mate!
Genius thanks so much - the support is great... money well spent !
Do you mind helping on another issue ?
15 years 11 months ago #2398 by nicolas
Sure.
Don't hesitate to open a new thread with your other question.
