Maximum articles per category
- louis.jonker@gmail.com
15 years 2 months ago #25005
by louis.jonker@gmail.com
Maximum articles per category was created by louis.jonker@gmail.com
I was wondering if there is a limit of articles per category.
In different categories i have about 90 products but the shop shows only 60.
Maximum articles in the shop is about 200 - 300
In system configuration display the value is columns 3 and number of items 2000
Has anyone a solution?
Thanx!
Louis
Thanx!
Louis
15 years 2 months ago #25011
Replied by nicolas on topic Re: Maximum articles per category
There is no limit.
You should look at the options of your menus and modules via the menu Display->Content menus/modules. You will find similar options which are used by HikaShop on your listings while the options in the config are only DEFAULT options for new modules and menus.
There is no limit.
15 years 2 months ago #25165
Replied by louis.jonker@gmail.com on topic Re: Maximum articles per category
I have changed the options in the menu Display > Content Menu but nothing happend.
Am I doing something wrong?
Louis
Louis
15 years 2 months ago #25166
If your menu is a category listing, the options are for the categories listing, not for the products listing. The options for the products listing are in the associated module. There is a link to it on the menu's hikashop options screen so that you can easily access it.
15 years 2 months ago #25186
Great, that was the right solution, evrything works fine now.
Thanks for the quick responses!
Louis
Louis
