Limit amount of a product per user, not per order
15 years 2 months ago #25448 by stattgarde
Hi!
We have a shop with a fixed group of users.
They have a quota and we want them to be able to buy a fixed amount (e.g. 10 pcs) of a product (e.g. show tickets).
I know you can configure a product with maximum amount per order but that would not prevent the user from placing additional orders with the same product, right?
Can you anywhere enter an all-time limit per user?
Kind regards, Simon
15 years 2 months ago #25457 by nicolas
Yes, that's possible with the "limit" feature that you can find in the commercial editions of HikaShop. You can access the configuration of limits via the "limit" button when you're on the products listing on the back end.
15 years 2 months ago #25532 by stattgarde
Thanks a lot! I just recently upgraded to the business version to use access levels and did not notice the new "Limits" option there.
14 years 8 months ago #44507 by raydesign
In this regard, is it also possible to set a maximum amount each user can add to the shopping cart?
I am in the same situation, with a closed user group. If possible, I would like to be able to set a maximum limit to each users shopping cart.
Example: User "A" can not add products for more than $400 to the cart. User "B" not more than $200 etc.
I only need 2 groups, and two maximum amounts, divided between full time and part time employees.
Thanks !
14 years 7 months ago #44652 by nicolas
Yes, you can restrict limit entries to user groups and thus users (Business edition) using the "access level" option of limits. And you can also limit the maximum amount to be purchased per order OR per period.
