featured products
15 years 3 weeks ago #28613
by machine40
featured products was created by machine40
I see there are no check to make a product featured, or for example only to make a module that shows ONLY, products with a valid discount.
whats the best system to make this possible with hikashop¿?
many thanks
many thanks
15 years 3 weeks ago #28635
Replied by nicolas on topic Re: featured products
You can just create a new category "featured" and add that category to the products you want featured (one product can have more than one category).
Then you can use that category in the parent category option of your featured module. If you don't want to see that category on a listing of categories on the front end, you can leave it unpublished and it will still allow your featured module to display its products.
There is an example of such module on our demo website if you need to refer to an example.
Time to create page: 0.042 seconds
