Double Variant for products
- grafikmania
14 years 11 months ago #30625
by grafikmania
Double Variant for products was created by grafikmania
Hello everybody and thank you for reading,
I've tried to find something similar to what I'd need to achieve but until now I had no luck, I hope someone could guide me in the right direction.
I'm using Joomla 1.7.2 with hikashop starter 1.5.4, I have some products where I need to create two set of variants.
Example, the main product is Photoframe, the first set of variants will have value referring to the colours, the other set will refer to the dimension of the frame.
I've created the list of value and created the variants of the product with these, but when I have to create the other variants with the colours I'm able to select just from the previous values of dimension.
Here is what I mean, set of values for the variants with dimension
image missing http://www.grafikmania.com/images/help/dimensioni.jpg
then the other one with the charecteristic colour
image missing http://www.grafikmania.com/images/help/colorecornice.jpg
Then I manage the variants in the product...
image missing http://www.grafikmania.com/images/help/managevariants.jpg
But I see just the values of the first variants...
image missing http://www.grafikmania.com/images/help/visualizzazionelast.jpg
I still can't find any solution, what I'm doing wrong?
Thank you again for reading and for your advice.
G.
G.
14 years 11 months ago #30673
Replied by nicolas on topic Re: Double Variant for products
That's because you didn't add both characteristic at the same time.
In the documentation, we explain how to solve that problem:
www.hikashop.com/en/support/documentatio...html#characteristics
1. Delete all the variants of the product on the listing of variants that you can access via the button "manage variants" on the product edition screen.
2. Delete the characteristics of the product.
3. Save the product.
4. Add the characteristics again.
5. The system will regenerate all the variants automatically and you should be able to see the dropdowns properly on the front end.
- grafikmania
14 years 11 months ago #30675
by grafikmania
Replied by grafikmania on topic Re: Double Variant for products
Thank you very much Nicolas, I'll try as soon as possible.
Time to create page: 2.215 seconds
