related products
14 years 11 months ago #30969 by plumbingdeals
quick question...
to move position of related products on product page, which view do i edit?
14 years 11 months ago #30986 by nicolas
Replied by nicolas on topic Re: related products
It's the file "show" of the view "product". Near the end of that the code below which displays the modules under the product page:
<div class="hikashop_submodules" id="hikashop_submodules" style="clear:both">
<?php
if(!empty($this->modules) && is_array($this->modules)){
jimport('joomla.application.module.helper');
foreach($this->modules as $module){
echo JModuleHelper::renderModule($module);
</div>
14 years 11 months ago #30991 by plumbingdeals
Replied by plumbingdeals on topic Re: related products
got it!
thank you sir!
14 years 10 months ago #33111 by zurli
Replied by zurli on topic Re: related products
i guess my products are displayed through Configuration - Display
There i set "Content of product page" to "Related products"
The related products are not show.
There is no change in show product file
Thanks for help
14 years 10 months ago #33116 by nicolas
Did you follow the explanations there www.hikashop.com/en/support/documentatio...ct-form.html#related ?
If yes, please post a screenshot of your module's hikashop options and of your product and a link to the product page so that we can see the problem.
14 years 10 months ago - 14 years 10 months ago #33208 by xkonidis
Replied by xkonidis on topic Re: related products
I'm having the same issue, I've done everything the documentation says, I even tried in a different order but for some reason the related products don't show up.
Here are the screens:
image missing http://www.smok-e.gr/screens/hika_content_module.jpg
image missing http://www.smok-e.gr/screens/hika_product_info.jpg
Thank you in advance,
Constantine
Edit
I've figured it out after crawling deep in here.. I had to select the "Synchronize with currently displayed item when possible" as well.
Everything seems to work now :)
Last edit: 14 years 10 months ago by xkonidis.
14 years 10 months ago #33498 by zurli
For me its working now, thank you very much
I guess xkonidis forgot step 3
For step 3 go to HikaShop --> System --> Configuration
select Tab "Display"
In the Display tab the 5. entry is Modules under the product page, there you can select your Related Products Module created in step 1 and 2
How to display your related products below your products:
1. Create a new module of the type "HikaShop content module" via the joomla modules manager and leave it unpublished in the joomla options of the module.
2. In the HikaShop options of the module (there is a link to them on the right of the module's joomla options screen), make sure that the "Type of content" option is set to "product" and that the option "Content on product page" is set to "Related products".
3. In the Display tab of the configuration of HikaShop, click on the "Select" button of the "Modules under the product page" option. Set your related module to published and click on OK. Then, save the configuration.
Time to create page: 1.196 seconds
