need some pro help over here :D
15 years 10 months ago - 15 years 10 months ago #3177
by koutanis
need some pro help over here :D was created by koutanis
Hello there.i have a problem wich i was hoping you can help me with.i have set up a site in wich the link to the ategories i want to "sell" arent menu links but images.Because this might be a little difficult to understand here is the link :
koutanistech.gr
. You will notice 4 big pictures in the center.those are my links to each category.i have reaqd many many times the guide but what i cant do is this : when you click to the hardware picture i have setup a module to show 2 sub categories in it,i made 2 random categories (one is mouse and the other keyboards).now what i need to do is when you go there and click on mouse to show the products i have under mouse in hikashop and when you click on keyboard to show the keyboards.so far i havent managed to find a solution.any suggestions? ty in advance for een reading this,i hope for a reply soon.
Last edit: 15 years 10 months ago by koutanis.
15 years 10 months ago #3181
Replied by nicolas on topic Re: need some pro help over here :D
I see that your four images do not directs to a listing of products but to a joomla article.
You should create a hikashop categories listing menu. Edit its hikashop options, set the "parent cateogry" and save them. There you will have a message to generate automatically a listing of products associated. Click on the link provided in that message.
Then, use this menu link as the link of one of your image.
Then, move that menu to a main menu which is not displayed on your template so that the menu is not displayed.
Finally, repeat the operation for each image.
15 years 10 months ago #3187
by koutanis
Replied by koutanis on topic Re: need some pro help over here :D
hi and thank you for your fast reply.yea the images lead to a link cause i couldnt find another way to link them to a page.i have the link from a menu that shows only to admins
.i will give it a shot and reply with any results.ty again for your fast answer
15 years 10 months ago #3213
by koutanis
hello again.i tried what you said but i now have a different problem.in order to show what we were trying to show after clicking the image you have to have at least once click the link from the menu module.if you go straight to the image it displays all of the categories with different backround settings etc that the ones it supposed to show.and i cant find out why this happens.if i log into and click the menu once (its hidden to admin view only) then it work like normal.(guess its the cookies).any suggestions?
15 years 10 months ago #3217
The link you're using for the images is not correct. You need to add to it the id of the menu your created.
For that, you need to add to the link the text "&itemid=ID" where you can replace ID by the ID of your menu.
15 years 10 months ago #3223
by koutanis
hi and sorry for bothering you again.i now dont get the message to auto link to a module.all i get is this : MENU_WITHOUT_ASSOCIATED_MODULE
ASSOCIATED_MODULE_NEEDED
ADD_MODULE_AUTO
HIKASHOP_SUCC_SAVED
i have no idea why this happens.all i did was delete all the menus to start over again and now it doesnt auto create a hikashop module :S
ADD_MODULE_AUTO
HIKASHOP_SUCC_SAVED
15 years 10 months ago #3224
Those messages will appear instead of their correspnding translation if something happened to the translation. Please revert the changes you made to your hikashop translation or load a new version from our servers. You can do that in the configuration, under the tab languages.
15 years 10 months ago #3230
by koutanis
It worked!!! i love you mate
ty so much
Time to create page: 0.124 seconds
