specific product detail in module
14 years 10 months ago #32307
by msf1995
specific product detail in module was created by msf1995
Is there a way to load the product detail in a module? I would like to have a specific product and its options to be displayed on my home page.
14 years 10 months ago #32338
Replied by nicolas on topic Re: specific product detail in module
You can't load that in a module.
However, you can have a product page on your front end.
For that, just create a menu item of the type hikashop product page via the menu manager of joomla and set that menu as default. Then it will be displayed in the main area of your home page.
14 years 10 months ago #32347
by msf1995
Replied by msf1995 on topic Re: specific product detail in module
Thanks Nicolas,
I did, in fact, have the product page linked to my HOME menu item as the default page and was able to build other modules around it nicely. The problem was the page title. Is there a way to override the product title as page title? I would like the product on the home page, but want the page to be titled "... Home Page..." or something similar.
Michael
Michael
14 years 10 months ago #32380
Forcing the title can be done with some code in the file "show" of the view "product" via the menu Display->Views, with something like that:
if($this->element->product_id==YYY){
$document =& JFactory::getDocument();
$document->setTitle( 'home page' );
14 years 10 months ago #32391
by msf1995
Thanks again, Nicolas
14 years 10 months ago #32401
by msf1995
Hi Nicolas -
Just to wrap up the thread.. For whatever reason, the setTitle code you suggested would not work for me. After searching a while I found this variation that does the job:
<?php
if (@$_REQUEST = 'frontpage') {
$document->setTitle("Homepage");
Again, Thanks for your help.
M
<?php
M
