can not stay on the same page after add to cart
14 years 10 months ago - 14 years 10 months ago #33078 by loling
Hi Nicolas
i just updated hikashop to 1.5.5. Then i played in checkout process. After changing some checkout workflow, i couldn't stay on the same page after adding product to cart.
I believe the option is in hikashop configuration - checkout tab - "After a product is added to the cart" - "always stay on the same page"
I have tried every option in "After a product is added to the cart", all of them give the same result, which always go to checkout.
I would like to have "always stay on the same page"
!!edit!!: it turns out that if we add product to cart from product page it works fine. It goes to checkout process when in listing page
!!temporary solution!! : Replace display-view-product-listing_img_Desc code:
<!-- ADD TO CART BUTTON -->
<form action="<?php echo hikashop_completeLink('product&task=updatecart'); ?>" method="post" name="hikashop_product_form_<?php echo $this->row->product_id.'_'.$this->params->get('main_div_name'); ?>"><?php
$this->ajax='';
if(!$this->config->get('ajax_add_to_cart',1)){
$this->ajax = 'return hikashopModifyQuantity(\''.$this->row->product_id.'\',field,1,\'hikashop_product_form_'.$this->row->product_id.'_'.$this->params->get('main_div_name').'\');';
$this->setLayout('quantity');
echo $this->loadTemplate();
<input type="hidden" name="product_id" value="<?php echo $this->row->product_id; ?>" />
<input type="hidden" name="add" value="1"/>
<input type="hidden" name="ctrl" value="product"/>
<input type="hidden" name="task" value="updatecart"/>
</form>
<!-- EO ADD TO CART BUTTON -->
back to old version of hikashop 1.4.9
?><form action="<?php echo hikashop::completeLink('product&task=updatecart'); ?>" method="post" name="hikashop_product_form_<?php echo $this->row->product_id.'_'.$this->params->get('main_div_name'); ?>"><?php
$this->ajax='';
</form><?php
i'm not sure whether this is good thing to do, at least it works for now.
Last edit: 14 years 10 months ago by loling.
14 years 10 months ago #33102 by nicolas
Thank you for the feedback.
You won't have any drawbacks by doing that modification.
We'll look on our end to fix that (the change is necessary in some other cases).
