Problem adding multiple varients to a product
15 years 10 months ago - 15 years 10 months ago #3358
by rob99
Problem adding multiple varients to a product was created by rob99
Hi, firstly thanks for what seems to be a great product! I have just installed the free version and I'm starting trying to add products and find my way around.
I have added an item of clothing and I want to add 3 varients: Size, colour & Stitching colour.
The size came up fine and works just right but when I try to add the other varients I get the message: "No values found" instead of a drop box and the text and image from teh body of the product also does no appear.
I've added a couple of images to explain further.
1st image showing one varient and everything looking good.
image missing http://img401.imageshack.us/img401/2702/novalues2.jpg
2nd image showing no values and body missing.
image missing http://img547.imageshack.us/img547/5849/novalues1.jpg
Hopefully someone can offer advice!
Rob.
Rob.
Last edit: 15 years 10 months ago by rob99.
15 years 10 months ago #3363
Replied by nicolas on topic Re: Problem adding multiple varients to a product
If you add new characteristics to a product which already had characteristics, the variants might not be updated/inserted automatically. In such case you need to edit/create the variants yourself via the "manage variants" button when editing your product.
15 years 10 months ago #3367
by rob99
Replied by rob99 on topic Re: Problem adding multiple varients to a product
Excellent advice. Problem solved. Many Thanks
15 years 10 months ago #4248
by animevortex
Replied by animevortex on topic Re: Problem adding multiple varients to a product
Hi Nicholas,
is there a quick way to add the variants by copying the previous variant and editing it properties?
15 years 10 months ago #4251
You have two options:
1. create the variants yourself via the manage variants button.
2. Delete all the existing variants for your product. Then, remove the characteristics from your product and save it. Finally, add all the characteristics back. That way, the system will automatically create all the variants again and you won't see the "No values found" message anymore.
Time to create page: 1.235 seconds
