A few minor problems
14 years 10 months ago #34531 by noelj
A few minor problems was created by noelj
I stumbled upon a few minor problems that I would like some help with:
  • The date display on invoices is currently: 05 January 2012, but I would like to change this to 05-01-2012.
  • I would like to remove the links to product in the shopping cart. I know you have somewhat explained how to do this in the manual, but I think it's from older code because the line of code that you need to change looks different now.
  • Lastly, I would like to remove the links from the checkout process bar. People can click the next step in the process bar even though they haven't entered an shipping adress yet (and the next step button is hidden as well).
If you could help me with any of these, I would very much appreciate it.
14 years 10 months ago #34575 by nicolas
Replied by nicolas on topic Re: A few minor problems
You need to edit the file "invoice" of the view "order" of your back end template via the menu Display->Views and change the line:
<?php echo JText::_('DATE').': '.hikashop_getDate($this->element->order_created,'%d %B %Y ');?><br/>
<?php echo JText::_('DATE').': '.hikashop_getDate($this->element->order_created,'%d-%m-%Y ');?><br/>
for the invoice of the back end.
2.
To remove the links to the product pages of products in the cart, you will need to edit the file "cart" of the views "product" and "checkout" for your front end template via the menu Display->Views and change the line:
<a href="<?php echo hikashop_completeLink('product&task=show&cid='.$row->product_id.$url_itemid);?>" ><?php echo $row->product_name; ?></a>
3.
It the file "step" of the view "checkout" and you need to change the code:
<a href="<?php echo hikashop_completeLink('checkout&task=step&step='.$k.$url_itemid);?>">
<?php echo JText::_('HIKASHOP_CHECKOUT_'.strtoupper($step_name));?>
</a>
14 years 10 months ago #34624 by noelj
Replied by noelj on topic Re: A few minor problems
Thanks once again for the great support, the changes all work great.
Time to create page: 0.042 seconds
