HikaShop modify positions help
14 years 10 months ago #34610 by gtstars
I just bought a new template for my Dream Girls site dreamgirlsgt.com/store.html If you notice at the bottom my products are not alined at the top.
My HikaShop starter is a little messed up but I love the software :)
How can I fix this? I know I need the CSS file but where do I find it in the dir?
14 years 10 months ago #34650 by nicolas
That doesn't come from HikaShop but from your template. You should check with your template provider.
I've looked for a solution but I only found a half backed one. It will sort of work but it's far from perfect. You should edit your HikaShop front end CSS via the Display tab of the configuration of HikaShop and add that CSS:
.hikashop_products_listing_main div{
clear:none !important;
.hikashop_products_listing_main .hikashop_container{
height: 200px;
Time to create page: 0.040 seconds
