Adding extras to products
- plantpotphil
14 years 10 months ago #34849
by plantpotphil
Create your own style of luxury bespoke furniture online
Adding extras to products was created by plantpotphil
We have 20 products (furniture such as sofas etc) - each of which is made with 2 characteristics: Fabrics (100 variables) and Legs (6 variables).
So one product has 600 child products (100 fabrics x 6 legs).
We'd also like to offer the the extra service of adding buttons to the furniture. This adds a fixed cost of +£200 to he product.
To do this I have created a characteristic called "Buttons" in which there are 2 variables: "Yes" or "No".
However, doing this doubles the amount of child products to 1200 for each product. Which is overkill because we don't need anything different for each child product other than adding £200 to the price.
Is there a way to add a fixed amount the product just by using a checkbox for example?
Any advice welcome!
Thanks,
Phil
Any advice welcome!
Thanks,
Phil
- plantpotphil
14 years 10 months ago #34850
by plantpotphil
Replied by plantpotphil on topic Re: Adding extras to products
An example of such a product can be viewed here:
www.clothierjones.com/bespoke-furniture/...chaise-longue-medium
14 years 10 months ago #34870
Replied by nicolas on topic Re: Adding extras to products
Yes, instead of using a characteristic, you should use an option:
www.hikashop.com/en/support/documentatio...ct-form.html#options
We have an example of product which uses options on our demo website:
www.demo.hikashop.com/index.php?option=c...ow&Itemid=91&lang=en
- plantpotphil
14 years 10 months ago - 14 years 10 months ago #34914
by plantpotphil
I actually tried using options as a solution by creating a whole new product called "buttons" with a price of £200. I then added this product to the furniture as an option.
However, at the checkout stage the user can click the "buttons" product and is taken to the product page for the buttons (which isn't really a product by itself). Can this be disabled only for certain products? Or is tere a way I can stop people adding this product to their cart by itself?
Last edit: 14 years 10 months ago by plantpotphil.
- plantpotphil
14 years 10 months ago - 14 years 10 months ago #34915
by plantpotphil
I've just noticed that on your demo site the options don't come up as their own product in the checkout. How is this possible to setup?
14 years 10 months ago #34917
That's because you need to turn on the option "group options with products" in the Checkout tab of the configuration.
- plantpotphil
14 years 10 months ago #34919
by plantpotphil
perfect!
Thanks Nicolas
Thanks Nicolas
Time to create page: 0.099 seconds
