Products Not Found
14 years 9 months ago #36296 by doug4r
Products Not Found was created by doug4r
I have imported 5240 product records and receive a message that the import was successful and 5240 product records were added.
"product_code","categories","product_name","product_weight","price_value","product_published"
"300.N.CC","Name Metal Plates","300 Name (ONLY) Chrome on Chrome Plate","1","19.93","Yes"
My guess is it wants something other than "Yes" for the field "product_published"
Doug
14 years 9 months ago #36331 by nicolas
Replied by nicolas on topic Re: Products Not Found
Yes. It should be 1 and not Yes.
14 years 9 months ago #36335 by doug4r
Replied by doug4r on topic Re: Products Not Found
I changed it to "1", but I still have the same problem.
14 years 9 months ago #36336 by nicolas
Do you see the products in the back end ? Could you give a link to your products listing on your front end ?
14 years 9 months ago #36339 by doug4r
No. The products are not seen in the backend.
yourcarthings.com
You can see the products in the front end by doing a search. For, example, search for "Honda". If you select the product categories and then click on a category, no products for that category will be displayed.
14 years 9 months ago #36369 by nicolas
Did you configure a category listing menu in the menu option of the hikashop categories search plugin ? If not, you should do it.
Then, if you don't see the products, neither on the front nor on the back end, it means that they weren't added by the import. Could you try again to import them ?
14 years 9 months ago #36372 by doug4r
The menu item type is "Categories Listing".
The products can be seen on the frontend by doing a search; such as "Honda"
14 years 9 months ago #36421 by doug4r
I just "unistalled" HikaShop, reinstalled it, and then imported the products again. I also manually added a product. Neither one of these allowed me to get a display of the products in the backend.
Very strange.
Doug
14 years 9 months ago #36453 by nicolas
Could you provide a back end access so that we can see that ?
14 years 9 months ago - 14 years 9 months ago #36459 by doug4r
Login: ******
Password: ********
Last edit: 14 years 9 months ago by nicolas.
14 years 9 months ago #36468 by nicolas
Cela ne fonctionne pas.
Veuillez nous fournir un compte valide via notre formulaire de contact plutot que sur le forum pour plus de sécurité.
14 years 9 months ago #36469 by doug4r
Huh?
14 years 9 months ago - 14 years 9 months ago #36508 by nicolas
Sorry, it was late :)
The account does not work. Please provide a valid access via our contact (for more security).
14 years 9 months ago #36572 by nicolas
All your products have a quantity of 0. So that means that they have no stock.
And in the Display tab of the configuration, you set the option "Display out of stock products" to No.
So that's why you don't see your products on the front end. If you turn on the option you will see them.
