Product Display Help
14 years 10 months ago #36949 by cimran
Product Display Help was created by cimran
I want to show my products similar to this layout
www.demo.hikashop.com/index.php?option=c...ng&Itemid=70&lang=en
Present layout is this one:
www.gtrlighting.com/store/category/13-hid-lighting.html
Thanks n take care
14 years 10 months ago #37070 by nicolas
Replied by nicolas on topic Re: Product Display Help
Go in the menu Display->Content modules, edit the module with the id 23 and change the layout type to "table" and you will see you products listing like that.
14 years 10 months ago #37103 by cimran
Replied by cimran on topic Re: Product Display Help
Thanks alot.. Thank you very much
But there is no option coming of next pages...like 1,2,3...>>
14 years 9 months ago #37230 by nicolas
On that same option screen you will find the option "random" which must be turned off for that. Also, the pagination will only display if you have more products to display thant the "number of items" you specified on that screen.
14 years 9 months ago #37946 by cimran
Is it possible to remove the word "Each" from next to the price?
Instead of it showing: "$220 each" could it say: "Price: $220" ?
Plz check www.gtrlighting.com
thank You
14 years 9 months ago #38061 by nicolas
Yes, you can do that by overriding the translations related to the price:
14 years 8 months ago #41228 by cimran
When i hover on Variants of products, It shows different sizes of pics that whole page moves ups and downs with variants....!!
Is there any way to Resize the Variant Pics by some fixed scale...
www.gtrlighting.com/component/hikashop/p...-conversion-kit.html
14 years 8 months ago #41415 by nicolas
If you just set the thumbnail height and not the thumbnail width in the Files tab of the configuration, that should do what you want.
