How to make Postcode specific products
14 years 9 months ago #36991
by IanK
How to make Postcode specific products was created by IanK
I have 13 products each of which are unique to certain postcode areas. How do I ensure that the correct product displays to a registered and logged in user? Some of the products will be available in post codes with different letters ie PA01 - PA20 , NE01 - NE24 and also ZE01 - ZE13 Can the postcode be entered with a wild card, ie PA01* to represent PA01 2TX?
I'm using Hikashop Essential
14 years 9 months ago #37110
Replied by nicolas on topic Re: How to make Postcode specific products
There is no option to do that.
That would require to have a hikashop plugin be made specifically to check a custom field of your products based on the post code entered by the user when registering.
14 years 9 months ago #37186
by IanK
Replied by IanK on topic Re: How to make Postcode specific products
Thank you Nicolas. Can you give me an indication of how much a custom plugin like this would cost to implement?
14 years 9 months ago #37326
I forwarded your request to the person in charge of custom works and he should get back to you shortly.
