Products not showing after import from .cvs
14 years 9 months ago #37627 by tatupatu
I ve tried to import products from .cvs
The header looks like:
product_code,product_name,categories
The import was done, the categories were set up, i see all the products at administration interface but not in the front end. Allthough the categories are visible also at the front end.
Then I ve deleted the products and reimported the .cvs, but then i got the following message:
"The product is of the type but it already exists in the database and is of the type variant. In order to avoid any problem the product insertion process has been skipped. Please correct its type before trying to reimport it."
Any suggestion?
Thanks in advance
14 years 9 months ago #37724 by nicolas
If you see your products on the back end and not on the front end, it's likely not related to the import but to the way you configured your menu/module.
We have tutorials for products/categories display on the front end that you should follow in those cases:
www.hikashop.com/en/support/documentatio...splay-front-end.html
For the error message, I'm not sure but that would mean that the products are still in the hikashop_product table of the database. Could you check on that via phpmyadmin ?
14 years 9 months ago #37928 by tatupatu
So i ve followed the tutorial, but without success, products are still invisible. I am sure, i am missing something very trivial. I send you the sreenshots, maybe you can find the missing part of the picture...
14 years 9 months ago #37930 by nicolas
That is fine. Then, make sure that your products are published and that they have a quantity (or unlimited).
14 years 9 months ago #37932 by tatupatu
Thanks a lot. Done. The quantity was missing (i m using only catalogue mode).
