Checkout and shopping cart module.
- brainforge
15 years 10 months ago #3837
by brainforge
Checkout and shopping cart module. was created by brainforge
Have shopping cart displayed on left hand side.
Click on proceed to checkout.
In checkout / login / registration screens the shopping cart is still displayed - this is unnecessary when in checkout.
This maybe something I would want to control in my Joomla template as I may not want to display either of my margins when in the checkout.
15 years 10 months ago #3841
Replied by nicolas on topic Re: Checkout and shopping cart module.
In the configuration of HikaShop there is the option "Force a menu on the checkout" in the tab display.
In this option, you can select a menu which will be applied on the checkout instead of the previous menu. That way, you can personnalize your modules to not be displayed on the checkout page.
15 years 10 months ago #3851
by tpioh
Replied by tpioh on topic Re: Checkout and shopping cart module.
does this mean i would have to create a checkout article or a hidden menu?
15 years 10 months ago #3857
A hidden menu yes. You can set it to a main menu which is not displayed in your template so that it doesn't appear if you don't need a link to it visible.
