Checkout work flow & Terms and Conditions
14 years 9 months ago #38499
by Pit Pony
Checkout work flow & Terms and Conditions was created by Pit Pony
I have the following checkout work flow
Cart Shipping
Login
Address
Payment
Fields Status
I would like to add terms and conditions before login, if I do it doesnt invoke until after the payment option screen, when I am then returned back to the start of checkout (cart).
I have tried adding (secondary option) after payment but I am still returned to start of checkout (cart).
Is it possible to have it just return back to the terms and conditions screen until the box is ticked ?
Cart Shipping
Login
Address
Payment
Fields Status
14 years 9 months ago #38647
Replied by nicolas on topic Re: Checkout work flow & Terms and Conditions
When we test on our end, the system returns to the correct step when the user didn't tick the box.
If you want to stop the user immediately on the terms view, you will have to edit the file components/com_hikashop/controllers/checkout.php and add the line:
return $this->check_terms();
after the line:
$app->setUserState( HIKASHOP_COMPONENT.'.checkout_terms', JRequest::getInt('hikashop_checkout_terms',0) );
after the line:
The following user(s) said Thank You: Pit Pony
Time to create page: 0.038 seconds
