Solution to Display # and Results 1-11 of 11
15 years 10 months ago #3854 by panosa73
I would like to disable showing "Display #" and "Results 1-11 of 11" under the Category Listings. I did find one post that refers to this but was not very helpful. I see that on the your demo site it's not showing.
www.demo.hikashop.com/index.php?option=c...ng&Itemid=59&lang=en
It would be the equivalent of appearing right under "HikaShop Store".
Again, I tried looking at the settings on the demo site but didn't find it.
Any help would be appreciated.
Thank you.
15 years 10 months ago #3860 by nicolas
The pagination will be displayed by default for the categories listing.
On our demo website, since we don't have a lot of elements, we decided to hide it. You can look at the HTML at the top of the listing of categories, there is the pagination but it is hidden with some CSS.
The pagination won't be displayed if you don't have any categories to display or if you're not displaying the categories listing as a menu but as a module since in both cases you don't want to display it.
15 years 10 months ago - 15 years 10 months ago #3879 by panosa73
Ok, I got it.
Go to administrator/components/com_hikashop/helpers/pagination.php
Line 174 is -> return $html;
Right before that add $html=""; or, just change it to return "";
That's it.
Last edit: 15 years 10 months ago by panosa73.
15 years 10 months ago #3880 by nicolas
That is not a good way of doing it. As I said in my post, you should do it with some CSS: www.hikashop.com/en/support/forum/2-gene...81-uk-only.html#3307
If you do it by editing that PHP file, you will loose your modification when you update.
15 years 10 months ago #3926 by panosa73
Ok, got it.
This is the actual css that worked for me:
div.limit{ display:none; }
span.hikashop_results_counter{ display:none; }
Thank you.
