Pagination not showing in products listing
15 years 10 months ago #3877 by KayKay
I have the number of item set to 15 and number of columns set to 3 for a category. Now I have 19 products
under that category but it's only the first page that is showing up with 15 products without any link to the next
page. Just wondering if I'm missing a setting or something.
15 years 10 months ago #3878 by nicolas
If the option "random" is on then no pagination is displayed since it's not logical to display a pagination when items in the listing changes each time you see the listing. Thus, you should turn off the random option in the menu/module which is displaying your products.
15 years 10 months ago - 15 years 10 months ago #3901 by gemmill
Edit...
Never mind, Found it...
***New Edit....
Is there any way to move the page selection buttons to the bottom of the products?
Last edit: 15 years 10 months ago by gemmill. Reason: I'm a bit slow....
15 years 10 months ago #3916 by nicolas
14 years 3 months ago - 14 years 3 months ago #57560 by Cstrike
Hi I checked all the Display->Content modules settings, all of them the Random items is set to "No" and still the product pagination is not showing... any other suggestions?
I have it so that it shows 3 columns and 6 items, but i have a total of 10 items in that category...
Last edit: 14 years 3 months ago by Cstrike. Reason: one more line
14 years 3 months ago #57633 by nicolas
Can you give a link to the page where you have the listing so that we can tell you which module you should look at so that you can do a screenshot of its options ?
12 years 8 months ago #144124 by mm89127
I have turned off the option "random" however there is no pagination in my product list. I have 30 product and have set the limit to 9,
Any suggestion?
12 years 8 months ago #144267 by nicolas
Please provide a screenshot of the options of your products listing and a link to the page so that we can analyze the situation.
