Problem with menu
14 years 8 months ago - 14 years 8 months ago #39374 by marste
Problem with menu was created by marste
Hello, I'm trying Hika shop but I get in trouble.
I have created category product but doesn't work and show bad.
The menu is different from template installed on my site, you can see here www.321studios.it/nhos15/index.php?optio...ng&Itemid=13&lang=it
Below module Category of Product there is another named Test and this one must be the layout correct. Why the module created by Hika do not keep the same style?
Stefano
Last edit: 14 years 8 months ago by marste.
14 years 8 months ago #39517 by nicolas
Replied by nicolas on topic Re: Problem with menu
That's because you need to configure the hikashop options of your module properly if you want to have the same display.
Set the layout to list, with no child displayed and in the UL class name option you need to enter " menu-sidebar" (note the space at the beginning) so that the list display uses your template CSS.
