Related Products&Default order status
14 years 9 months ago - 14 years 9 months ago #39654 by marko05nikolic
* I have problem with related products. When i add new product, i select few for related but thez dont displey.
* When i buy product my status don't change to default order status i my case CREATED, I must go in back-end to change first in created then then in confirmed or cancelled.ž
* How I can remove this?
some help or ideas.
thanks
Last edit: 14 years 9 months ago by marko05nikolic.
14 years 9 months ago #39847 by nicolas
1. You need to configure a related products listing module. Please follow the documentation on that:
www.hikashop.com/en/support/documentatio...ct-form.html#related
2. If your orders are not automatically validated after the payment is made on your payment platform, then you probably have one of these problems:
www.hikashop.com/en/support/documentatio...or.html#notification
3. You can edit the front end CSS file of HikaShop via the Display tab of the configuration and add some CSS like that:
.hikashop_order_product_code{ display:none;}
don't forget to save the configuration after that.
