How to... move my products in cart over to left...
15 years 10 months ago #4077
by gemmill
How to... move my products in cart over to left... was created by gemmill
Hi all,
This might be asking a bit much, but I thought I'd try anyway.
in the attached image, you can see my cart contents are too far over to the right, and i'd like to move them to the left so they fit.
the other menus are not over this far.... just the shopping cart.
Thanks in advance for any help.
Much appreciated.
Stu.
Much appreciated.
Stu.
15 years 10 months ago #4082
Replied by nicolas on topic Re: How to... move my products in cart over to left...
Could you give us a link to to your page ? It would help to test the CSS with firebug (an addon to debug CSS on firefox)
15 years 10 months ago #4083
by gemmill
Replied by gemmill on topic Re: How to... move my products in cart over to left...
Thanks nicolas... you're very helpful
jonnybgifts.com
its not live yet so..
user = guest
password = hikarules
jonnybgifts.com
user = guest
15 years 10 months ago #4085
You can add the CSS:
.hikashop_cart{ margin-left: -30px; }
Either add it in the configuration of HikaShop in the tab display in the area CSS, or in your template CSS file.
15 years 10 months ago #4086
by gemmill
15 years 10 months ago #4088
Yes. You also need to use that frontend_custom.css file in the dropdown (so you have to save the configuration).
15 years 10 months ago #4089
by gemmill
15 years 10 months ago #4090
Mmm, that CSS is superceded by the CSS in your template.
Please try instead this one:
div#hikashop_cart{ margin-left : -30px; }
15 years 10 months ago - 15 years 10 months ago #4092
by gemmill
didn't work.....
Should I try editing my template css?
edit..
I tried putting the first line of code you gave me in the template .css.... no change
(well at least I think thats where I put it)
edit..
Last edit: 15 years 10 months ago by gemmill.
15 years 10 months ago #4094
Again, the CSS is overriden by your template CSS.
Let's do it differently.
Please edit your template css file jonnybgifts.com/templates/siteground-j15-123/css/template.css
near line 769 you will have
Please remove the line
#leftcolumn div.module_menu div div div div,#leftcolumn div.module div div div div,#leftcolumn div.module_text div div div div,
#rightcolumn div.module_menu div div div div,#rightcolumn div.module div div div div,#rightcolumn div.module_text div div div div {
background: none;
margin:0 auto;
padding:0;
color:#a51313;
margin:0 auto;
15 years 10 months ago #4095
by gemmill
Perfect!
You're a champion.
Thank you so much.
Stu.
You're a champion.
Thank you so much.
Stu.
