Import from VM not work
14 years 8 months ago - 14 years 8 months ago #42456 by lives
Hi, i try to import from VM
but i see this
HikaShop: Importa da VirtueMart
[Initialization Tables]
Elasped time: 135.75ms
Prosegui
If i click on prosegui, the page is refreshed.
i use vm1.1.9 and joomla 1.5.25
Thank's
sorry for my english :P
........ ops, this is wrong section of forum? :S
Last edit: 14 years 8 months ago by lives.
14 years 8 months ago #42631 by nicolas
Replied by nicolas on topic Re: Import from VM not work
What if you turn on the debug mode of the joomla configuration and try again ?
Do you get some errors when doing the import ?
Also, try with another browser.
And try to click several times on "continue".
14 years 8 months ago #42811 by lives
Replied by lives on topic Re: Import from VM not work
When i turn on debug mode i dont see any errors..
If i try another browser i see this error
[Import Taxes]
Import taxes: 1
Imported Taxes Categories: 1
Imported Taxations: 1
Elasped time: 120.89ms
I try whit firefox, crhome and safari.
I click severl time on continue, but the problem not solved.. :(
Help me please
joomla 1.5.25 vm 1.1.9
14 years 8 months ago #42818 by nicolas
The message you posted now is different. It seems that the import is moving from one step to another as it should.
Please continue until the end of the import.
14 years 8 months ago #42827 by lives
But the import is stopped
in i click continue nothing happens :(
the import not work, is blocked in this point
14 years 8 months ago #42828 by lives
Is possible to import csv?
i export a csv of vm, but in another post you said
to change header of file, whath is header? sorry,
but my english is very bad :silly:
14 years 8 months ago #42841 by nicolas
Then I don't know why that would happen.
For the import of CSV file, before doing it, you need to open the file and change the column names in order to fit with the column names in HikaShop. To know what are the column names in HikaShop, create one product in HikaShop and export it. In the CSV file, you will be able to see what column name is for what information.
14 years 8 months ago #42952 by lives
sorry, how to export csv from hikashop?
14 years 8 months ago #43085 by nicolas
You can go in the products listing and click on the export button.
14 years 8 months ago - 14 years 8 months ago #43137 by lives
Ok nicolas, thank's, i export products from hika...
Now... how to exprot product from vm?
i try whitk csvi vm export, when i try to export i see this windows:
i try all 5 option, but work only export in xml file...
the other export generate i file like this
but the file is empty.. :(
14 years 8 months ago #43273 by nicolas
I suppose that you first need to create a CSVi template. You can follow the tutorial here:
www.csvimproved.com/index.php?option=com...&catid=33&Itemid=142
14 years 8 months ago #43278 by lives
:( but is very difficult :(
14 years 8 months ago #43469 by nicolas
Yes. That's why we made the import from VM. It's really strange that it doesn't work for you.
Maybe you could try to do a copy of your website on your local computer and do the import from VM there. That might help avoid the problem you have on your website with it...
14 years 8 months ago #43505 by lives
Ok nicolas, i copy site in my pc e try to import from vm..
14 years 8 months ago #43545 by lives
dont't work :(
HikaShop: Import from VirtueMart
Elasped time: 298.44ms
Next
i click next every time, but don't work :(
A question nicolas, is possible to import product from xml file?
or is possible to implement this features in next version?
Thank :)
14 years 8 months ago #43559 by nicolas
Could you give a back end access to your website so that we can have a look at the import from VM ?
It's strange that it doesn't work for you.
XML import is not possible for now. We won't implement it for next release as we are already working on other things for next release. Also, it's not really a priority as there are other features more requested that we want to do before that.
14 years 8 months ago #43716 by lives
I send you pass for my back and... please, see why the import dont work,
i dont understand :(
14 years 8 months ago #43720 by nicolas
For some reasons the page was not fetched again when pressing next.
I had to press ctrl+F5 for it to go to the next step each time.
That way, I was able to finish the import on your website.
14 years 8 months ago #43722 by lives
You are great :)
I try this way in local and work great :)
But at the end i see this message
You can publish the VirtueMart Fallback Redirect Plugin so that your old VirtueMart links are automatically redirected to HikaShop pages and thus not loose the ranking of your content on search engines.
This plugin redirect301 the old links?
14 years 8 months ago #43723 by nicolas
Yes, but you need to keep VM on your website if you use it.
