MouseOver Effect For Product Images
14 years 8 months ago #42708 by rbedica
Hi There
Is there any option to create move over effect on product images. Means we dont have to click on the image to see large image rather then when we point the mouse over the image it shows the large image instead of clicking it. Pls help regarding this.
14 years 8 months ago #42713 by nicolas
You can change the line:
<?php echo $this->image->display(@$image->file_path,true,@$image->file_name,'id="hikashop_main_image" style="margin-top:10px;margin-bottom:10px;display:inline-block;vertical-align:middle"','id="hikashop_main_image_link"', $width, $height); ?>
<?php echo $this->image->display(@$image->file_path,true,@$image->file_name,'id="hikashop_main_image" style="margin-top:10px;margin-bottom:10px;display:inline-block;vertical-align:middle"','id="hikashop_main_image_link" onhover="SqueezeBox.fromElement(this,{parse: \'rel\'});return false;" ', $width, $height); ?>
in the file show_block_img of your front end template via the menu Display->Views in order to do that.
The following user(s) said Thank You: janevert
14 years 8 months ago #42716 by rbedica
Thanks Nicolas. I tried but its still not working even after changing the code its still showing large pic after clicking. Can you help?
14 years 8 months ago #42717 by nicolas
Please make sure that you do the change for the correct template.
14 years 7 months ago #44140 by rbedica
i have updated the file "show_block_img" in my frontend template (i applied this on the template i am using). But still image is getting big after clicking on it not on the "Mouseover" . Following is the entire code of the changed "show_block_img" file. Please suggest if i am doing some thing wrong. Also can i have this effect on product listing page as well
<?php
* @version 1.5.6
* @author hikashop.com
<div id="hikashop_product_image_main" >
<div id="hikashop_main_image_div" class="hikashop_main_image_div">
<?php
if(!empty ($this->element->images)){
$image = reset($this->element->images);
$height = $this->config->get('product_image_y',$this->config->get('thumbnail_y'));
$width = $this->config->get('product_image_x',$this->config->get('thumbnail_x'));
if (!$this->config->get('thumbnail')) {
echo '<img src="' . $this->image->uploadFolder_url . $image->file_path . '" alt="' . $image->file_name . '" id="hikashop_main_image" style="margin-top:10px;margin-bottom:10px;display:inline-block;vertical-align:middle" />';
} else {
$style = '';
if (!empty ($this->element->images) && count($this->element->images) > 1) {
if (!empty ($height)) {
$style = ' style="height:' . ($height +5) . 'px;"';
<div class="hikashop_product_main_image_thumb" id="hikashop_main_image_thumb_div" <?php echo $style;?> >
</div>
<?php
</div>
<div id="hikashop_small_image_div" class="hikashop_small_image_div">
<?php
foreach ($this->element->images as $image) {
echo $this->image->display($image->file_path, 'hikashop_main_image', $image->file_name, 'class="hikashop_child_image"','', $width, $height);
</div>
</div
14 years 7 months ago #44332 by nicolas
In my previous code, it should be "onmouseover" instead of "onhover"
The following user(s) said Thank You: sarawhite
14 years 7 months ago #44523 by rbedica
Gr8 its working perfect on the product page thanks.... Gr8 Support from Gr8 Product..... :)
13 years 11 months ago - 13 years 11 months ago #79773 by janevert
Hello i have change this and work perfect but can i do this also on the next page www.universal-gemstone.com/index.php/com...cedoon.html?Itemid=1
to "onmouseover" where do i have to change it and into what?
Last edit: 13 years 11 months ago by janevert.
13 years 11 months ago #79835 by nicolas
Here is a thread which talks about that for listings:
www.hikashop.com/forum/4-how-to/49351-sh...r.html?lang=en#49421
In your case, you're apparently using the listing_img_desc item box layout and not the default listing_img_title mentioned in that post but the code to use should be pretty similar.
Note though that the code of the image display changed a bit since then so it might require some modification. Let us know if it doesn't work and what and how it doesn't work.
13 years 11 months ago - 13 years 11 months ago #79848 by janevert
So fare its work ok , only the half of the screen become gray so i tried just to change the mouseover into mouseclick and its works perfect
13 years 11 months ago #79850 by Jerome
I think this is a problem with the Joomla "modal" library and your template.
13 years 11 months ago - 13 years 11 months ago #79854 by janevert
I will leave it with the mouseclick that work ok, with the mouseover you can get greasy like mentioned before in this topic.
so thanks for the help
13 years 1 month ago - 13 years 1 month ago #126466 by viki667
Hello
Can anybody tell me how to switch off this mouseover thumbnails effect on product page? I mean that when i move mouse over thumbnail image (orientation: portrait) the image hides away thumbnails at the bottom.. <<<< Look at pic 1
it came after i tried to solve the problem on the second image (Product page) whereby i changed the configuration->Display->css
.hikashop_product_main_image_thumb{
margin-bottom:-100px;
and completely another question about this MouseOver Effect...
changing the php code in: listing_img_title" of the view "product". doesn't for some reason work and i noticed this php code is much longer there than written above...
And thank you soo much hikashop team.. love the product - learning every day :)
Laadukas moderni kulmasohva, valkoinen kulmasohva tai iso kulmasohva: ModerniKoti
Last edit: 13 years 1 month ago by viki667.
13 years 1 month ago #126475 by Jerome
There is in HikaShop an option to set the image size for the product page.
These dimensions (height and width) creates some kind of virtual box where the images would be displayed. So the box will always have the same size.
If you want, you can override the view "product | show_block_img" to change how the images are displayed in the product page.
You will be able to change mostly everything.
If you are using HikaShop 2.2.2 (that I will recommend you), the popup system and the mouse hover have been moved into the view instead of using a specific function in a class (that was harder to override).
So HikaShop 2.2.2 is easier for override the images in the product page.
The following user(s) said Thank You: viki667
13 years 1 month ago #126495 by viki667
Jerome wrote: Hi,
gosh, it really worked, thank you so much Jerome :) :) :)
13 years 1 month ago #127787 by PubSite
Is there a way to add this effect to the carousel? The only thing is, I don't want the image to be maximized. I just want to be a little bigger when mouse hovers on it. I think this is a feature the carousel should have by default. But what can I do about it now that it doesn't have it as a default feature. I really need it. Please HELP!!!
13 years 1 month ago - 13 years 1 month ago #127805 by Mohamed Thelji
I think that this can be done by using some CSS code customization like :
.YourCarouselClass img:hover { width: 300px; }
Last edit: 13 years 1 month ago by Mohamed Thelji.
The following user(s) said Thank You: PubSite
13 years 1 month ago #127833 by PubSite
I did this:
.hikashop_main_carousel_divimg:hover {
width: 300px;
.hikashop_main_carousel_div ul li{
padding: 0px !important;
background: none !important;
.... is it correct?! because I didn't get any result.. I found one CAROUSEL in my CSS and I added to it. I think I did it wrong because I got no results. Help me out please!
13 years 1 month ago #127867 by Xavier
You will have to apply it on a parent div:
[code]
.hikashop_main_carousel_div .hikashop_product_image:hover{
width: 300px;
13 years 1 month ago #127887 by PubSite
Dear Xavier.. I did as you said and all I get now is a movement to right which is not correct as you can see in this link : 212.113.141.199/~pubnew/newcatalog/index.php/fa/ ... what I'm looking for is a kind of effect which won't move the items but just enlarges the images a bit.. right where they are... Thanks for the help you've given me so far.. It would be great if you tell me where my flaw is... I'll provide the CSS as well..
.hikashop_main_carousel_div .hikashop_product_image:hover{width: 300px; }
.hikashop_main_carousel_div .hikashop_product_image:hover{width: 300px;}
