MouseOver Effect For Product Images
13 years 1 month ago #127944
by Xavier
Replied by Xavier on topic MouseOver Effect For Product Images
The best way to do what you want is to use your browser console to find the classes / divs you need
Here is a tutorial which explain how to customize the layout:
13 years 3 weeks ago #129130
by PubSite
Replied by PubSite on topic MouseOver Effect For Product Images
I haven't got a reply form you yet.. this is very important to me. Please give me a code that would give me a kind of TRANSITION like "grow" for example. Thanks
13 years 3 weeks ago #129196
by Xavier
Thanks to the css3 there is zoom in effect, thanks to see this website:
www.vinhhungle.com/create-simple-css3-zo...fect-on-mouse-hover/
And as I said in my previous post, all you need to know is in this tutorial:
We generally don't provide help for customizations, it is mainly a support forum regarding the bugs or configurations issues
11 years 11 months ago #182977
by armanemadi
With them the Seed of Wisdom did I sow,
And with my own hand labour’d it to grow:
And this was all the Harvest that I reap’d—
“I came like Water, and like Wind I go.”
Replied by armanemadi on topic Re: MouseOver Effect For Product Images
in hikashop update will display and view code also update ? i mean may be my customize code will replace with new codes
tankas
tankas
11 years 11 months ago #182978
by Xavier
Replied by Xavier on topic Re: MouseOver Effect For Product Images
If you edited the views via the menu Display > Views, or via ftp in the template folder so no, you will not loose the customisations.
9 years 4 months ago #273497
by jomytago
Replied by jomytago on topic MouseOver Effect For Product Images
