Problem with compatability of my Joomla template
- marlenevdc
14 years 7 months ago #43247
by marlenevdc
Problem with compatability of my Joomla template was created by marlenevdc
I have a problem with the compatability of HikaShop and the template I'm currently using.
I downloaded your Starter kit and installed it to Joomla and it worked perfectly. However, when I load the template I want to use on the website to Joomla, the HikaShop component disappears.
Any idea why this could be happening?
14 years 7 months ago #43385
Replied by nicolas on topic Re: Problem with compatability of my Joomla template
Isn't the problem because your menu module is assigned to a position which doesn't exists in your new template ? Thus, reassigning it might do the trick.
Could you give a link to your website so that we can see that ?
- marlenevdc
14 years 7 months ago #43392
by marlenevdc
Replied by marlenevdc on topic Re: Problem with compatability of my Joomla template
I'm not sure if that is the problem, as the Component disappears completely once I load the template.
So, if I load HikaShop and then go the Admin panel and hover over the Component menu item, I can see it. The minute I install my template and then hover over the Component menu item, HikaShop is gone.
The website is : www.herbalworx.co.za/dev .
14 years 7 months ago #43399
Could you do some screenshots so that we can see the problem ?
