HELP. Artisteer, Hikashop and CSS
14 years 7 months ago #44554 by Starhorsepax
Maybe I've already asked - I've lost track where I've posted. Can anyone tell me how to get an artisteer 3.1 menu to work with Hikashop? Module class suffix half works: the mouseover changes color on the vertical menu. However, for some reason the main button color on the vertical menu isn't loading. I've tried Inspect Element / Firebug and found nothing anywhere to explain what the conflict is. It seems to be taking the standard link color instead of the menu color.
It should be white/light background, rounded corners (from the image file) with no text decoration and a green background on mouseover also with no text decoration.
Apparently the green Vmenu png is loading but the there should be (I think) 3 Vmenu blocks loading for the white with borders that aren't.
I've also posted in artisteer forums so I know this version should be compatible with Joomla 2.5 and Hikashop.
Here is the Site.
14 years 7 months ago #44659 by nicolas
You should set the "UL class suffix" option of your module in the hikashop options of your module to the artisteer UL class of your template. I can see that you've already set it to old-vmenu
So that it basically.
14 years 7 months ago #44714 by Starhorsepax
Therein lay the problem. I've done what it says to do: but it's not entirely working. Something MUST be overwriting part of the css. But I can't find it!
14 years 7 months ago #44730 by Starhorsepax
The attachment shows how it SHOULD look. Mouse over is green (that part works fine)
14 years 7 months ago #44734 by nicolas
Would it be possible for you to publish a joomla menu on your website so that we can see the CSS used there so that we can compare it with the CSS of the HikaShop ?
Because otherwise, it's impossible to say what's missing.
