Showing Products in a 2-Up VIew
15 years 10 months ago #4460 by DavidBShapiro
I have set the default display as DIV and set the columns to 2 but the products are still showing as though there is only 1 column.
www.fitsolutionsnaples.com/index.php?opt...out=listing&Itemid=1
Is there a setting that I need to change
15 years 10 months ago #4461 by nicolas
Each menu/module has its own options.
The default options of the configuration are just default options which will be used for new menus/modules.
You should go in the menu Display->Content menus and your menu (id 1) and set the number of columns option there.
