Cart Module does not display proper price
14 years 7 months ago #45547
by smattson
Cart Module does not display proper price was created by smattson
Hello, I purchased the Essentials package and I am having an issue with the cart module. I have two instances of this module. The first is on the left sidebar of the merchandise page. The second is a view cart link accessible from and of the pages on the client's site. The link points to an article that has the module loaded into it using the {loadmodule mod_hikashop_cart} plugin. This instance of module only displays the "cents" of the products in the cart. For instance, if a product sells for "24.99", the value in the left sidebar cart shows "24.99", but the view cart page only displays ".99". Thoughts? Thanks.
14 years 7 months ago #45677
Replied by nicolas on topic Re: Cart Module does not display proper price
That's because you have a plugin which removes the $text in your joomla articles.
If you want to avoid that, you can add a space between the symbol and the price by editing your currency via the menu System->Currencies and turning the corresponding option.
The following user(s) said Thank You: smattson
14 years 7 months ago #45698
by smattson
Replied by smattson on topic Re: Cart Module does not display proper price
Perfect, it worked. Thank you for your reply!
