How to change the order of the products?
- Juffrouw Zonder Zorgen
14 years 7 months ago - 14 years 7 months ago #46180
by Juffrouw Zonder Zorgen
How to change the order of the products? was created by Juffrouw Zonder Zorgen
Can someone help me with this problem?
When one adds products at the backend of the hikashop, Hika Shop always post those last added products at the end of the product list. Is there an option to change this so the last items are automaticly put on top of that list?
The only option that I see at this moment is to change the order by clicking the arrows on the product overview at the Hika Shop module and when you added like 100 products it's a hell of a job. I also tried to change the option 'order' in the 'main standard option'\'view'\'configuration' but all in vein...
Last edit: 14 years 7 months ago by Juffrouw Zonder Zorgen.
14 years 6 months ago #46290
Replied by nicolas on topic Re: How to change the order of the products?
In your products listing modules and menus, you can just change the ordering column and order direction to "product_id" and "DESC" and that will do what you want.
You can edit the modules and menus via the menu Display->Content menus/modules.
14 years 6 months ago #46295
Replied by Juffrouw Zonder Zorgen on topic Re: How to change the order of the products?
Thanks!
