Problem with product Picture
15 years 9 months ago #4672
by 4duded
Problem with product Picture was created by 4duded
Hi how i can center the immage of the product box or is possible that the picture fit the box without white border ?
I attach one immage so you can understund better
image missing http://www.scmarconi.it/images/Immagine1111x.JPG
http://www.scmarconi.it/images/zzzzImmagine111.BMP
15 years 9 months ago #4679
Replied by nicolas on topic Re: Problem with product Picture
The problem is that the display is handled by the joomla modal popup library and it renders differently depending on the browser and since it's an image directly in an iframe you can't apply CSS to it. What you could try is to personnalize the modal popup chrome in your template CSS file.
For example, you could change the white background to black by adding the CSS code below to your template CSS file:
#sbox-content {
background-color: #000000;
15 years 9 months ago #4684
by 4duded
Replied by 4duded on topic Re: Problem with product Picture
Sorry friend I'm new ...where i can found the css
many thanks for all help !
15 years 9 months ago #4685
This tutorial explains how to modify a joomla template, including how to edit your CSS:
www.ultijoomla.com/blog/How-To-Edit-Joom...emplates-part-1.html
