Same Characteristics applied to multiple products
14 years 7 months ago #46973 by Runham
Business version on Joomla 2.5
I have created a set of characteristics for a number of variants of a print, e.g. frame sizes, with description, weight, price etc. Is there any way to retain this data so that when I then apply the characteristics to a 2nd print I don't then have to re-enter all the informaion. I want a standard set of characteristics for all prints I have available - it is going to be tedious in the extreme to have to enter this information for each characteristic for each product.
14 years 7 months ago #47052 by Runham
14 years 7 months ago #47312 by nicolas
You have a copy button on the product listing which allows you to easily duplicate a product and the characteristics setup. Then you just have to modify the product specific information.
14 years 7 months ago #47314 by Runham
I tried that, Copying a product with characteristics doesn't seem to work properly - For instance, I have a single product, a print, which has a characteristic with 4 options, if I copy that product, then in my category listing on my shop front I now show 5 products instead of 2 when there are only 2 products.
14 years 7 months ago #47619 by nicolas
That's really strange. We didn't get any feedback on that end for that feature.
Are you able to reproduce that on our demo website ? If so, could you give a step by step in order to reproduce the problem ?
13 years 7 months ago #98836 by tiekubd
What about if you have already created a 100 products, and then later created a characteristic (let's say size). Is there a way to apply to the 100 products, because this is my situation?
13 years 7 months ago #99072 by nicolas
Unfortunately no.
You will have to add it manually for the 100 products.
