Cart quantity input override not working
14 years 7 months ago #47601 by Density5
Just want to say thanks for all your help so far, we are nearly done with out build and I must say I'm really impressed with how customisable Hikashop can be.
I have a slight problem overriding the quantity input in the cart. I have enabled the Ajax option and am following the instructions in the Developer Documentation, but I think there might be an error there.
I have created the file templates/MY TEMPLATE/html/com_hikashop/hikashop_button.php - is that the correct name? I have also tried naming it hikashop_quantity.php.
In this file I have copied all the code from administrator/components/com_hikashop/helpers/cart.php, just under the check for the override, and added a simple message, but I'm not seeing it displayed so I don't think my override is being picked up at all.
I've attached a copy of the file, if you could have a quick look I'd be most grateful.
Thanks in advance,
Jerry
14 years 7 months ago #47777 by nicolas
The path should be: templates/YOUR_TEMPLATE/html/hikashop_button.php
It's in the documentation: www.hikashop.com/en/support/documentatio...tation.html#override
Also, you should not copy all the code, but create a function declaration and only add the relevant code.
14 years 6 months ago #48763 by Density5
Hi Nicolas, thanks for your reply, even after reading the documentation and your reply several times I failed to spot my mistake so I'm posting it here as a warning to others to pay attention to the detail!
The files does NOT go in <template>/html/com_hikashop it goes directly in <template>/html!
D'oh!
