Cart Module - display custom field
14 years 6 months ago #49479 by Nanni
I would like do not display the custom item fields in the cart module.
In the Hikashop options for the Hikashop Cart Module, I selected "NO" in "Display custom item fields".
But They continue to be visible.
Is it necessary some other settings?
14 years 6 months ago #49558 by nicolas
If you want to remove the display of the custom fields on the cart during the checkout you will need to add that CSS:
.hikashop_cart_product_custom_item_fields{ display : none; }
There is no display of the custom fields on the cart module, so changing that option in the cart module's options won't do anything.
14 years 6 months ago #49669 by Nanni
OK. I understand that I had a wrong idea.
My problem was to avoid a too long custom field list in the cart module, that I positioned in the left column of the template.
I solved modifying the file: views/product/tmpl/cart.php, putting the item field list in a new table row instead of in the same td of the product_name.
The eshop is now online ( www.larcos.it ).
Time to create page: 0.041 seconds
