How do I set pagination default to "all" products?
14 years 6 months ago #50468 by jberry210490
Hi there,
I want to keep the pagination unit at the bottom of product listings, but where as it's current default is to display 20 products per page, I want the default to be set to "all" products.
How do I do this?
Thanks in advance,
Jonathan
14 years 6 months ago #50529 by nicolas
In the HikaShop options of your menus and modules (that you can access via the menu Display->Content menus/modules), you have the option "number of items". Set it to 99999 and it will display all the products as long as you don't have more than 99999 products on a page.
Please note though that having too much products on a page can slow down the display of a page so it's always good to set a reasonable number of products per pages (not more than a few hundreds).
The following user(s) said Thank You: jberry210490
14 years 6 months ago #50562 by jberry210490
Thankyou for the quick reply.
When I do this though, I remove the pagination controls at the bottom of the page. I want to show all products, but still enable the individual to change the number of products displayed on a page. Is this possible?
Jonathan
14 years 6 months ago #50649 by nicolas
That should be the case actually, unless you're displaying your products listing directly with a module.
Can you give a link to that page so that we can see how you setup your listing ?
14 years 6 months ago #50715 by jberry210490
claycellar.org/index.php/tools
I've currently set number of products to be displayed in the associated content module and menu to be 300. But I still want pagination to be displayed.
Jonathan
14 years 6 months ago #50761 by nicolas
Your website is not accessible without a user account.
Please make sure that you set the option in the associated module's options. Because if you set it only in the category listing menu's option, it will apply only for the category listing, not the products listing displayed below it with the associated module.
14 years 6 months ago #50769 by jberry210490
Sorry, that was just whilst I was backing up the site.
You'll be able to access it now...
Jonathan
14 years 6 months ago #50847 by nicolas
I was able to check your website.
I think I now understand what you want.
You will have to edit the file "listing_div" of the view "product" via the menu Display->Views and change the line:
<?php if(in_array($pagination,array('bottom','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total > $this->pageInfo->limit->value){ $this->pagination->form = '_bottom'; ?>
<?php if(in_array($pagination,array('bottom','both')) && $this->params->get('show_limit')){ $this->pagination->form = '_bottom'; ?>
so that it always displays the pagination area regardless of whether all the products are displayed or not.
