JFolder::create: Cant create folder problem
14 years 5 months ago - 14 years 5 months ago #51469 by Dramacydril
Can anyone help me please. I have the following problem.
When i go to the VIEWS option and select listing_table(or any file) and try to save i get the following errors:
Error Saving
JFolder::folder: Path is not a folder
Could not make the file /templates/xxxx/html/com_hikashop/product/listing_table.php writable
Warning: file_put_contents(/templates/xxxx/html/com_hikashop/product/listing_table.php) [function.file-put-contents]: failed to open stream: No such file or directory in /home/xxxx/public_html/libraries/joomla/filesystem/file.php on line 304
Warning: Invalid argument supplied for foreach() in /home/xxxx/public_html/administrator/components/com_templates/helpers/template.php on line 62
Anyone know the solution? I will give you my login if thats necessary.
Last edit: 14 years 5 months ago by Dramacydril.
14 years 5 months ago #51560 by nicolas
Please make sure that the folder /templates/xxxx/html/com_hikashop/product/ exists and that it is writable via FTP and it will work.
