Fix Products and Catgories tables
14 years 5 months ago #53589 by zaurb
I've accidentally dropped tables:
hikashop_product
hikashop_product_category
hikashop_category
hikashop_cart_product
I've re-imported from CSV the products and categories data and received a message that all products were successfully imported, however nothing appears under products.
When I go to Products --> Categories in the Explorer window I see nothing, however I see all the categories in the main screen with categories listing.
Products are not seen at all.
Is there a way to fix this or I have to remove HikaShop completely and reinstall it again?
Many thanks in advance!
14 years 5 months ago #53596 by ryand500
Hi there
I think you can fix this by going to your hikashop export file, go to the colomn that says product quantity and changing all of your products to -1, which is unlimited stock, supposing you do.
Or you can go to System | Configuration | Display | Default parameters for products and change the setting to 'display out of stock products' to yes
Hope that helps
14 years 5 months ago #53684 by nicolas
Do you have your products in the hikashop_product table ?
Try to import again the CSV with the debug mode of the joomla configuration activated. That might display an error if there is a problem with the database (for example if you didn't add back a table of HikaShop properly).
