Problems displaying 2 colums per page.
15 years 9 months ago #5385 by JWeb5
I have tried to reassociate the menu items and went into product id to change the display. Clearing cache and everything else too. I've changed the default values in the main hika config's. no luck.
please help!
15 years 9 months ago #5386 by nicolas
The default parameters in the hikashop config are just default options for new modules and menus. For existing ones, you need to edit their options. You can edit your menus/modules hikashop options via the "hikashop options" link in your modules/menus options or access them directly via the menu Display->Content menus and Display->Content modules.
15 years 9 months ago #5389 by JWeb5
I've done that.It isn;t working. Everything is still displaying as one column aligned to the left side of the pagecontent area.
15 years 9 months ago - 15 years 9 months ago #5390 by JWeb5
I've cleared page and hika cache and browser cache.
It's like that whole parameter/valueis commented out,and I don'tknow where it is or it's working string.
I'm completely baffled
Last edit: 15 years 9 months ago by JWeb5.
15 years 9 months ago #5391 by nicolas
Could you give a link to your page where you have that 1 column problem ?
15 years 9 months ago #5392 by JWeb5
15 years 9 months ago #5394 by nicolas
I see two columns on that page.
You have the same problem as explained on that thread I suppose because your looking at your page with IE:
www.hikashop.com/en/support/forum/2-gene...-product-layout.html
That bug is fixed in the latest version of Hikashop so if you update it should go away.
15 years 9 months ago - 15 years 9 months ago #5395 by JWeb5
Thank you!
