Address Problems
14 years 5 months ago #53976
by Faust
Address Problems was created by Faust
I have the workflow set up to ask for the address during login/right after but the modal window to add the address information.
Attached is a screenshot. Why is this?
- Thank you received: 1778
14 years 5 months ago #53978
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re: Address Problems
I think that it might be because of your template. Could you try to use another front-end template and tell me if it works ?
If not, you should activate the debug mode of the config of joomla and try again. That might display an error message about the problem.
14 years 5 months ago #53980
by Faust
Replied by Faust on topic Re: Address Problems
Thank you for the reply. I've tried the templates that come with Joomla and still have the same problem. Turning on debugging didn't come up with anything either.
Is there anyway to just have the address information on the main page and not in a popup modal window?
14 years 5 months ago #53981
by Faust
The address fields are also not showing up in the login screen. Please see attached.
14 years 5 months ago #54035
by Mohamed Thelji
Ok, can you show me a screenshot of your customfields listing ?
14 years 5 months ago #54108
Replied by nicolas on topic Re: Address Problems
Please download HikaShop from our website and install it again. That should fix the problem.
The following user(s) said Thank You: Faust
14 years 5 months ago #54131
by Faust
Did a newer version just get put up? Reinstalling it solved the problem. Thanks!
14 years 5 months ago #54220
It was just a patch for the release we did last week.
